Hard Start for First Crank When Hot
Second start attempt will be just fine, fires up right away. Even if it's just a second after the first. It's gotten to the point that I'll usually bump the engine over a couple turns, let go of key, and then start it up. It's kinda embarrassing that it doesn't want to start on first attempt.
Seems like it has gotten worse since installing headers. Again, once started it will idle fine and run great, just doesn't like to start or first cycle after sitting hot.
Any ideas?
solenoid a hard time, getting to contact. Does it grunt
and try to turn, just "ka-chunk" (solenoid but no spin)
or click (not even solenoid pull-in)?
Maybe the heat is doing something to the fuel pressure? I would check the pressure cold, then hot, see if there's a difference.
Strange.
Maybe some kind of vapor lock going on.
Also, I was thinking about cutting a door for the fuel pump. I've heard 98s have a different location for cutting then the other f-bodys. Can anyone confirm this, and know where to cut?
Is it the same as the LT1s?
I would think that if it was really leaking down through the pump or the injectors then if it sat for a long period it would be hard to start as well since it would have longer to bleed pressure.
I will post my results.
