Hard Start for First Crank When Hot
1) Fuel Pump - I'll want and see what happens wioth your's
2) Injectors - Cheaper and easier to replace and I feel like this may be what it is. Been looking at these and it seems right http://www.speedinc.com/cont.cfm?cid=C0000845
I'll say this...I have had this problem for 5 years on my 98 Z. I'm simply fed up at this point and want to resolve it.
My setup is fairly stock, air filter to manifold upgrades, a catback and some performance tuning that was included with some of the PCM issues I had (for more on that all you have to do is ask as it is another rediculous ghost of a problem that was resolved)
I'm not one to just dump money into parts just for the hell of it, but my build has led me to put in the following all new parts:
NGK TR55 plugs
MSD 8.5mm wires
MSD Coil packs
PCV Valve
HP Starter
HP Alternator
0 Gauge Battery terminal wires
Fuel Filter
IAC
TB
Z06 MAF
Crank Sensor
Cam Sensor
MAP Sensor
IAT Sensor
and a host of other parts. Some went bad, some needed to be put in because of stereo, some I wanted to upgrade. I think it is safe to say we are narrowed down to a Fuel issue at this point.
You should do the fuel pressure test-that'd be the cheapest/easiest thing to do above all...
100% Agreed - On the way out to get the gauge now. I meant what I said from a labor perspective, but yes you are right overall. Any idea of what the numbers should be assuming the pump is A-OK?
Thanks!
http://www.youtube.com/watch?v=uuo57yox3sc
Those of you who are experiencing a similar problem I would suggest borrowing or buying a fuel pressure gauge that attachs at the fuel rail schrader valve. Check your fuel pressure with the engine off and turn the key to the on position. Then check it with the engine running. Check both several times and then post your findings to this forum.
Good luck.
I went out to buy a gauge this weekend and the knuckle draggers at my local P3pBoyz do not have it. They might have had it in stock...but I am sure they wouldn't be able to find it. How do I know this you ask? -
Well when I told the guy basically, "I need a fuel pressure gauge for a GM car to check fuel pressure"
He asked, "What type of car?"
I responded, "Camaro"
He responded, " Camaro... Is that a Chevrolet?" Understandable right??? Well he said Chevrolet like this: "Shev-Row-Let" lololol
So I walked out before he found a way to sneak a Ford part in my car
Seriously though, 2 things on my end. If someone who has a better idea which fuel pressure gauge I should buy, whether it be on amazon, ebay, anywhere please shoot me a link so I can pick one up online and check my pressure.
2nd thing - I have a buddy who bought a crate LS1 couple years ago. Came with 28lb injectors (stock for 98 F-Bodys which I have) He promptly upgraded the motor and and needed to buy new ones before the motor was even run. So brand new he is going to loan them to me, they work I will buy em, they don't work, they just go back to him for use in something else so it isn't the end of the world.
Ideally I want to have them in by Wednesday/Thursday night that way I can flog the car over the weekend and see if the heat issue is resolved. Have doubts seeing as though the pump looks good so far.
All this was done on a car lift. I have a flowmaster catback on my car and instead of cutting the exhaust pipe that flows over the axle we slide it off the y-pipe and let the curved section that goes over the axle hang on the axle. Disconnecting the right rear shock and removing the spring allowed the axle to hang low enough so that the exhaust would be out of the way making the fuel tank come out easier.
Bottom line, check your fuel pressure before you start pulling stuff off.
I pulled up Junkman's manifold removal procedure as I had intentions of changing the injectors I was given to see if it solved my problem.
https://ls1tech.com/forums/generatio...n-dummies.html
I was pretty much dead in the water before I began. I bought the same "OEM" fuel line removal tool as in the 4th picture. It WOULD have worked, except the F-Body fuel line connecting to the rail is a little "shorter" and I can't get the tool around line completely. That was that and no injectors were changed. I have a buddy who owns a shop and has a low profile tool that will do the trick. Problem is I am flying out for work on Thursday, and unless one of us gets super ambitious in the next 72 hours I am not sure it is going to happen for a little while but we will see. Honestly, the whole removal is a joke, the biggest obstacles (for me) are getting that line off and my strut tower brace that needs to come off in order to clear the rails from the manifold. Will update on all this soon as I can. Bottom line on the injectors, got em brand new for free to test. Solve the issue or not the are mine for $150 if I want them so they are going in the car one way or another at least from a diagnostic perspective.
Circling back now, I am not sure my fuel pressure drop means anything at this moment. Like we all said, car starts every time when it is stone cold. It is the warm heat soaked starts that present the problem. Correct me if I am wrong, but that is when we want to see where the fuel pressure is at - when the car has been driven, has been up to normal temps for a little, and then has been let to sit. Then lets say an hour or 2 after it sits, go to start it, and the hard start is there.
Bet I can speak for most here when I say, All I want to do is blow off this work trip just to play with my car
Thoughts? Suggestions? Tips? Advice? - All are welcome. Please do tell me if I am doing something wrong, or should simply be trying something else.
gets pulled and mixture is modified, away from what the
real situation needs.
Try this - put the IAT sensor in your pocket next time and
plug it in right before starting. See what happens.
