Sponsored by: CARiD
Low coolant light
Old Dec 1, 2003 | 09:09 PM
chipabba's Avatar
Question Low coolant light
How do I get rid of a persistant "Low Coolant Light"? There's always plenty of coolant and I don't want to get into changing the sensor every other month. Any suggestions?
Old Dec 1, 2003 | 09:26 PM
jrp's Avatar
jrp
SN95 Director
make sure the sensor is clean and then reset the pcm, see if that takes care of it.
Old Dec 2, 2003 | 07:51 PM
Kurt D's Avatar
I think this is a problem mostly with alot of `99s. You can unplug it. That's the only way I kept mine off. It was cleaned once, then replaced, then I said to hell with it.
I don't think `00+ have them anyway, right?
Old Dec 3, 2003 | 01:09 PM
z98's Avatar
z98
I have a 98 and it does it often too. Not constantly, but every once in a while, even when the coolant is full.
Old Apr 24, 2005 | 07:22 PM
92 z28's Avatar
how do i remove it?
Old Apr 24, 2005 | 09:02 PM
ls1999ta's Avatar
there is a metal clip that holds the sensor on....thats it
Old Apr 24, 2005 | 09:10 PM
Mike98WS6's Avatar
Just clean the metal part of the sensor. Then u should be good.
Old Apr 25, 2005 | 10:10 AM
92 z28's Avatar
how do i remove the sensor itself from the radiator?
Old May 23, 2005 | 04:11 AM
LS1FIRE's Avatar
There is a metal clip locking it in. I removed the battery to get better access to the sensor. Lift up two sides of the metal clip and pull it towards the passenger side. and then pull the sensor out.
Old May 23, 2005 | 05:17 AM
waterbug1999's Avatar
Mine is stuck on too. Been like that for so long, I dont even see it anymore. Hell, with the ABS/SES light on it doesnt show up that bad!
