S.o.s
car runs fine when it starts up and when it reaches normal operating temp. but then after driving awhile i get a hesitation or a really bad miss upon take off i've replaced the MAP sensor, the o2 sensors, the coils and the plugs and wires and the no. 4 plug is darker than the other plugs, where as the other plugs are showing normal wear the no. 4 is dark around the ceramic part of the electrode, now i scanned the computer : 0 codes but i got an incomplete condition reading on the screen that read EVAP im thinking i may have kinked a line when i changed the fuel pump but i want to hear you guys opinions! Last edited by ODAWG; Sep 27, 2009 at 09:40 AM. Reason: left out something i've replaced on car to help diagnose problem.
Make sure that #4 plug wire is not touching any part of the exhaust pipe manifolds. If it is, or if any of them are......it will misfire. But you will not get misfires usually until your in the mid-to-upper rpm's and it will be worse after its hot. Most people get codes when it misfires, but I've learned that all PCM's do not act the same, so you might not get one.
If thats not it, swap that plug wire with a new one. Make sure its "snapped" on at both ends. If its loose it'll still fire sometimes, but it will also misfire.
You could swap coils to see if the problem moves with it, but you're not getting codes to tell which cylinder is missing.
