LS1 sluggish at low RPMs
My 99 SS LS1 runs very sluggish in 6th gear when trying to accelerate from 70 mph. When I try to pick up speed, it feels like it is missing....
NO Codes.....
Any thoughts?????
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
If the air filter is dirty replace it,and spray the MAFS sensor with some MAFS cleaner.
And check/change your spark plugs. Also Pull the intake and clean it out with some carburetor cleaner, and on the heads do the same with the intake runners. After you get it all back together install a catch-can. it should run smoother in 6th.
Or you can just down-shift into 5th, or 4th .
i love having 4 gears to chose from when passing...hell 5 if you're doing ~50
uncorking the TDs at 4000rpm to pass someone is GREAT!!!
untill you get pulled over 20miles later
If you have tuning software and log it, you will see that your MAP (or load) is actually quite high at that Rpm when you attempt to accelerate. In essence you are lugging the engine.
Having two overdrives in a car with as much power as a LS1 is a real luxury. In the 'old days' people who have loved to have had that. It lets you add aggressive gearing (3.73-4.10) and still cruise at relatively low Rpms at highway speeds.
You simply can not use a 2nd overdrive to accelerate your engine. I have seen the MAP go to its limits when you try it. It probably is not good for the engine. Down-shifting is what you have to do.
Hope that helps. Good luck, and take care of that engine!
..WeathermanShawn..
One of my most consistent tests I do to identify ignition components being faulty is drive a car at high load at low rpm. If I have worn plugs or a weak coil it'll show when I do this.
So also as stated try a set of plugs, maybe wires if you haven't changed them in a while. If it still does it you could have a weak coil.
You really need to watch it on a misfire monitor though, it's always hard guessing over the internet if what you say feels like a misfire is for sure a misfire.
..WeathermanShawn..
