Sponsored by: CARiD
winter storage?
Old Dec 27, 2009 | 12:41 PM
Mightymike2000ss's Avatar
From: Home town Clive,IA current town FORT BENNING GEORGIA
Default winter storage?
hey guys im kinda scared that my car will go to pieces this winter. i leave for basic training and will be gone for 4 months, i will have no-one to start the car for me while its stored inside my garage.
will my car be alright to sit for 4 months?
i just put sta-bil in it.
Old Dec 27, 2009 | 01:46 PM
eseibel67's Avatar
Change the oil.
Pump the tires up to 44 psi.
Get all the frech fries out from under the seat, or you will get mice.
Old Dec 27, 2009 | 01:55 PM
Ryans99ls1's Avatar
+ a trickle charger for the battery and your set.
Old Dec 27, 2009 | 04:45 PM
so its cool i was just worried my bottom end would get messed, or something come spring when i get it back.
Old Dec 28, 2009 | 06:39 AM
jam01's Avatar
i would fill the tank with gas plus fuel stabilizer, trickle charger and put the car on jack stands.
Old Dec 28, 2009 | 07:38 AM
eseibel67's Avatar
Skip the jack stands. It creates more problems than it solves. Just pump up the tires.
Old Dec 28, 2009 | 09:53 PM
jam01's Avatar
how does putting the car on jack stands cause more problems? it is a known fact that storing a car on the tires, causes low spots on the tires. putting the stands under the axle and control arms is your best bet. you could also use those silicone tabs you find in boxes for electronic devices. you can find more stuff for storage on restoration sites or even for corvette sites.
Old Dec 28, 2009 | 09:59 PM
pillarpod's Avatar
i would just park the car so it sits on cardboard on all four tires Thats must if you have high performace tires
Old Dec 28, 2009 | 11:00 PM
Scira's Avatar
https://ls1tech.com/forums/appearanc...lkthrough.html
Lots of good info in there.
Old Dec 30, 2009 | 11:40 PM
radchevy's Avatar
When the car is on jack stand it helps out in three ways.
1. Like said before keeps the tires from drying out
2. Takes the weight of the springs
3. When spring comes and the floor becomes damp you will will have more air floor under the car adn will prevent possible rust.
Old Dec 31, 2009 | 12:10 AM
99huggerorangeZ's Avatar
every year before i put mine away,which is usually the last week of september or first week of october depending on the weather patterns. i put a fresh 6 qts of mobil1 in,fresh full tank of 93 w/stabil fuel stabilizer,air up my tires,trickle charger,6 desicant bags(silica gel) for moisture inside and a full detail then i cover it with my california car cover in my heated/air condtioned garage and call it a day.i have been doing this for the last 10 years and i have never had a problem with my car,i do start it once a month just to keep the fluids moving and from the seals drying up. i installed a new set of bfg kdw w/american racing m-black torque thrusts last summer, so ill see how they fare when it comes spring time.
