PWR Steering Cap - Question
The question is the Cap, it is "wet" around there on the top and side, is this suppose to be an "Air Tight" seal, maybe that is letting air in and contributing? Fluid is getting out to some degree, I always assumed it was simple cap, keeping dirt out and fluid in.
Thoughts? I know a cap is cheap, so I can head down to Chev in the morning.
Thanks
BLEED PROCEDURE
•Tools Required
•J35555 Mity Vac
•J43485 Power Steering Bleeder Adapter
•Bleed the steering system for the following reasons:
•Components replaced
•Fluid line disconnected
•Steering system noise occurs
•Prevention of pump damage
•Proper system operation
IMPORTANT: Use clean, new power steering fluid type only.
•See Specifications.
IMPORTANT: Hoses touching the frame, body or engine can cause system noise.
•The hoses must not touch any other part of the vehicle.
IMPORTANT: Loose connections may not leak, but could allow air into the steering system.
•Verify that all hose connections are tight.
IMPORTANT: Maintain the fluid level throughout the bleed procedure.
•Remove the pump reservoir cap.
•Fill the pump reservoir with fluid to the "FULL COLD" level.
•Attach J 43485 to J 35555 or equivalent.
•Place J 43485 on the pump reservoir filler neck.
•Apply a vacuum of 20 Hg maximum.
•Wait 5 minutes.
•Verify the fluid level.
•Reinstall the pump reservoir cap.
