Sponsored by: CARiD
p0300 and p0412
Old Jan 21, 2010 | 09:00 PM
snkeater's Avatar
Default p0300 and p0412
well after an engine swap, i finally turned on my car and it idled ok until it warmed up and then it shut off. I tried turning it on again and it didnt turn on unless i gave it gas. I let it cool down and once it did i turned it on and it idled fine. I took it to autozone and got p0300 (multiple misfires) and p0412 (secondary air injection system fault). After doing research, I came to the conclusion that the p0300 code is caused by the p0412 code. there are no vacuum leaks, no kinked nor broken lines and all the electrical connections seem to be good. Spark plug wires are good, spark plugs are good and so are the coils. also, fuel pressure is 60 and oxygen sensors are new.....So im guessing that to fix my problem i would have to change out the air pump right??? what do you suggest. Thanks for your help
Old Jan 22, 2010 | 12:26 AM
snkeater's Avatar
ttt for tonight
Old Jan 22, 2010 | 09:48 AM
snkeater's Avatar
anyone??
Old Jan 22, 2010 | 10:33 AM
keliente's Avatar
Did you put another LS1 in it or something aftermarket?
I believe you are having two separate issues here. P0412 with the AIR system, and the P0300 being a random misfire.
In doing an engine swap there are several grounds. Are you sure that you reconnected each one? Especially the grounds that go on the back of the cylinder heads, those are muy importante...also there are a couple ground straps that go from the block to the body. I'd check all of those first since it's easy.
Secondly I would hook up a scan tool and see what the O2's are reading. Just because they are new doesn't mean there still can't be a problem.
The fact that the car runs fine cold but not when its warm might tell us that it has a problem when the car starts taking feedback from the sensors (closed loop).
Old Jan 22, 2010 | 11:58 AM
snkeater's Avatar
well i put a 6.0 block. Ive checked the grounds and they seem to be in there tight. thanks for your feedback ill check them 02 sensors.
Old Jan 22, 2010 | 12:33 PM
keliente's Avatar
Have you had it tuned yet?
Old Jan 22, 2010 | 02:18 PM
snkeater's Avatar
negative I just finished the 30 minute break in. I dont know if this has anything to do with these codes but as for right now im running open headers. Im planning to put the exhaust on as soon as I can fix them codes so I can drive it down to the exhaust shop
Old Jan 22, 2010 | 07:11 PM
snkeater's Avatar
a new air pump fixed code p0412 now im down to the engine stalling and code p0300
Old Jan 22, 2010 | 09:18 PM
edward_garcia_69's Avatar
I had a code p0300 on my 1997 z28 and found out the header had burned the wire harness coming from the pcm going to the 02 sensor. Check your wiring going to to 02.
Old Jan 24, 2010 | 02:36 PM
snkeater's Avatar
did it make the engine stall?
Old Jan 25, 2010 | 09:39 AM
keliente's Avatar
I would have it tuned first... that is probably the reason for the P0300 and also the stalling.
