Car stalls when I make a hard left?
Old 05-17-2010, 06:09 PM
Slash8915's Avatar
Default Car stalls when I make a hard left?
Here lately, my car has been stalling when I make a hard left. Whether it be a corner, or a sharp curve, it will randomly stall about half the time, then come back to life . Any idea what this could be?
Old 05-17-2010, 06:13 PM
jam01's Avatar
maybe a wire somewhere that only move's when making left turns. fuel pump or something just loose under the hood.
Old 05-17-2010, 06:16 PM
racerx82989's Avatar
will it do it when your stopped and you turn the wheel to the left? or only under lateral g's?
Old 05-17-2010, 07:00 PM
Slash8915's Avatar
Both...
Old 05-17-2010, 08:19 PM
BOA279's Avatar
sounds like a power steering pump...check your fluids to start. Something is putting a load on the motor when you turn the wheel and the only thing that does that is the pump.
Old 05-18-2010, 09:12 AM
Grimes's Avatar
I agree with electrical problem somewhere...check all your grounds are tight and in good condition.
Old 05-18-2010, 10:06 AM
lt1pwr1's Avatar
Yeah I agree, check your grounds. Initially I was thinking something was putting a load on your engine but if it doesn't do it turning to the right then you can probably eliminate that.
Old 05-18-2010, 10:41 AM
01ssreda4's Avatar
This exact thing happened to me in a previous vehicle. Turned out to be the positive battery cable chafing against the metal battery tray and giving the direct short. Talk about a potential disaster
Quick Reply: Car stalls when I make a hard left?
