Sponsored by: CARiD
A/C Problem?
Old Jun 14, 2010 | 04:35 PM
Gun5's Avatar
Default A/C Problem?
Well im certified in A/C's let me say first of all so we don't have to go through anyone explaining the basics
anyways here's the problem im having. A week or 2 ago i charged my a/c with 2 1/2 cans it blew cold for 4-5 days then went mild cold then warm. So i hooked it up last night it was showing a little low (because i didst use 3 cans obviously) so i was like ok maybe the sensors bad so i pulled the A/C-Cruise fuse and put it back in with the car running compressor clicked and starting snow balling.. now this morning its mildy cold again
another thing is since my H/C/I build my cruise control has not worked says clutch sensor sometimes and i had to replace the hi pressure line because it broke during the swap at the condenser
Old Jun 14, 2010 | 05:19 PM
fleetmgr's Avatar
Sounds to me like you have a bit of moisture in the system.
Old Jun 14, 2010 | 06:05 PM
Gun5's Avatar
well i vacuumed it for 30-45 minutes with that harbor freight filter you hook to your compressor and compressor was at 115 psi the whole time
Old Jun 14, 2010 | 06:38 PM
Gun5's Avatar
pulled the fuse and tried it again nothing blows alittle cold.. drier wont get cold but at the block at the back where the low and hi side lines meet it gets ice cold...
im guessing something is clogged here like the drier.. the thing is it was ice cold last night i had to run it on fan speed 1 because i was being frozen same as a week or 2 ago i would think it would never get ice cold if it was clogged thats what i was told before
Old Jun 14, 2010 | 08:02 PM
fleetmgr's Avatar
Pull the orifice tube and see if it's plugged.
Old Jun 14, 2010 | 08:43 PM
slow's Avatar
The LS1 uses 1.5#, each small can is 12 oz, so 2 cans should be a full system. You could be overcharged. (unless you found 8 oz cans somewhere)
That type of vacuum pump is not ideal, so there could still be moisture in the system, I will agree with fleetmgr on pull the orifice tube.
Ryan
Old Jun 14, 2010 | 09:34 PM
LS6427's Avatar
Originally Posted by fleetmgr
pull the orifice tube and see if it's plugged.
+1............someone had your same symptoms earlier this year and thats what it was. A clog.
Old Jun 14, 2010 | 10:24 PM
Gun5's Avatar
guess ill be doing that... damnit
Old Jun 15, 2010 | 08:42 PM
Gun5's Avatar
trying to find someone with a tank so i can bleed the freon into it and not waist it..
probably gonna do the drier if im doing the orifice tube... where is it located on our cars btw??
Old Jun 17, 2010 | 02:54 PM
samson_420's Avatar
I doubt that you have a R12 conversion and 134a is cheap. . . I know it's not by the book. . . But, let er' go.
You can't find the drier? And you are certified in what?
Old Jun 17, 2010 | 03:07 PM
vetteboy99's Avatar
You probably put to much in it from the first time. Or your comepressor is leaking from some where. What excactly did you recharge it with? frion? or something else??
Old Jun 17, 2010 | 11:06 PM
Carter Hays's Avatar
Orifice tube is in the evaporator inlet. Remove the liquid line and pull it out. The accumulator (drier) is staring you in the face.
What are your gauge readings? The basics.................
Old Jun 18, 2010 | 05:35 PM
Gun5's Avatar
talking about the orifice tube buddy not the drier lol and i found a buddy with a recycle machine im gonna go ahead and do both of the fore mentioned items thinking about the pressure switch too dnno if i should do it fixing to order all the little stuff my car needs which is just this stuff and a powersteering hi pressure line got that damn seep all f-bodys got
thanks thats what i was figuring.. i know thats one of the most common things besides leak/low charge is a clogged orifice
