power steering pump
http://www.youtube.com/watch?v=ujslj-830ck
Im not so sure how to use one of these things. I pretty much did what this guy did the video lol but Im afraid Im still not doin something correctly. I screw that bolt in, that thing only went in half ways. Im turning that nut & bolt same direction as that guy did in the video. feels like Im about to snap that bolt or something just dont feel right. Every other thread I came across said it was easy job yet not so easy for me
am I doin this right? just keep turning in the same direction as in the video or No?
I've got an old PS pump in the garage...give me a couple minutes and I'll try and toss up a couple pictures of the setup.
Edit: right, so no pics, but after looking at the setup for a second, without a collar removal tool, I don't think the pulley can be removed at all. The guy might be showing how to reinstall the pulley, but I don't think that'll work for removing it.
If you search for "power steering pulley puller" on Amazon, you should be able to pick up the kit you need. There's a couple different orange-box versions for different prices, but as far as I know, they're all the same.
Not one of the stores have a collar that fits. The collar is that two pieces comes apart goes over that nut piece &,that circle thing wraps around the whole thing. That is the collar rigght? Lol
I just can't find a collar that fits, do I even really need that thing
I wound up buying my kit off Amazon, although Harbor Freight has the exact same thing. Auto Zone shows a kit, p/n 27031 "OEM/Power steering pulley puller/installer", that looks like it's work. Without the puller, I'm really not sure how you'd get it off...I couldn't get either of my 2-jaw or 3-jaw pullers to work (aside from there not being enough room to get them in there, they would have just broken the plastic lip off), and to install, you'd have to get a long bolt with the right thread pitch, some nuts and washers.
I really dont wanna order this cause it always turns out its the wrong one. so where can I find this actull pulley puller. with the right collar I need. for this 99 camaro
I did it by cutting an open ended spanner in half with a hacksaw so I could get it on the bolts because it was too long.
Even with the right tools its still kinda a pain dealing with press on pulleys.
As stated you can the pump off with the pulley on but that is definately a pain.
Edit: I removed the link since its non sponsor but look this up...
KD Hand Tools 2897
As an alternate to the KD Tools set, this is the one I have, and is a little cheaper: http://www.harborfreight.com/pulley-...set-40749.html (don't think any sponsors sell it, so hopefully the link is ok...). You'll have to grind the half-moon collars a bit on the thick side, but it's nothing a couple minutes with a file or a quick pass with a grinding wheel can't fix.
That harbor frieght one posted looks like a pretty decent copy, if the parts are worth a crap that would be a decent one besides the having to grind on it to make it work part. KD makes really good stuff for a great cost, I would go with the KD if it were me.
