Power Steering Pully Wining + Smell Help
Found out my power steering is going out, what i would like to know is does any body get that burning smell??? Also does anybody know or have a write up on how to remove and replace the pully? and anything else i should know before performing this job; the wining is starting to get worse
all comments are appreciated Thanks!
Save the manuals!
I don't get a burning smell. How do you know its the pulley vs. the pump? Does the steering still feel fine?
Getting the pulley off is easy:
- Get PS Pulley Puller Tool
- Take the serpentine belt off
- Put tool on the pulley
- Turn shaft on tool and wait for the "pop" of the pulley coming off the shaft
Once you get the pulley off the shaft, you'll have easy access to the pump bolts if you need to take that off.
If you need a pulley, PM me. I have one in great condition.
Well when I'm at a red-light at idle is the only time I really get the smell on the freeway is when I hear the wining and the steering is real rough when turning specially on Uturns and slow turns it feels really rough!
Save the manuals!
Sounds like your pump is dead. Do you plan to keep your car for a while and do you need it to drive every day? If you are going to keep it around and can go without your car for a few days, I'd recommend sending it off to TurnOne for a rebuild and new pulley. Their pulley makes it a breeze to re-install.
can you explane in detail once i get the pully puller on how to take off the pully
all i am asking for is someone to help out a noob, we all have to start somewhere
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
you can rent them from a place like autozone... even the dumbasses that work there should be able to tell you how to use it.
best of luck if you dive into it yourself. nothings more gratifying then working on your car yourself... unless its motor mounts.... I ******* HATE THOSE THINGS!!!!
It is really easy. once u get the pully off, just take the hoses off and then the 2 bolts. there is a write-up on this forum somewhere. I just cannot remember which section it is in. Good luck.
i have had the tool the whole time this thred as been open i got it from autzone but the tool does not pull the pully off thanks for the input.. so i thought i was doing it wrong so i asked for conformation
Save the manuals!
Can you post a pic on the tool installed to the pulley? When you put the shackles on, do they get in the groove far enough to touch each other?
My puller was too fat to fit in the groove correctly and I had to do some modifications and other stuff to get it to work.
