Rattling Noise during WOT
I have checked everything on mine too, and it has the some what of the same symptoms. Only under WOT I hear a rattling noise coming from the drivetrain like if the u joint is bad, again only UNDER WOT, because I turn it on nothing, I drive normal nothing. My car is an A4 with 150k+ miles transmission rebuild at 130k, trying to figure this issue out too.
Subscribe
Subscribe
i had a similar issue, but it only happened everyonce in awhile. found out all the dowel pins from my monster clutch came loose and they were rattling/bouncing around the bell housing.
It seems there are a few issues revolving around the same noise. This makes the most sense so far since I had one of my 02 sensors replaced not too long ago. The noise was gone for a while and it came back. Before I knew what it was, the car used to act like it was mis firing one a start up every once a while.
