Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- Camaro and Firebird: How to Change Power Steering Fluid
Step by step instructions for do-it-yourself repairs
Power Steering Cooling Success
#81
wssix99 in post #1, his cooler is stand off style, he seems to be getting sufficiently lower temps.
If the temp is 150-160°F vs 200-210°F then I will be happy.
Thanks for taking some temp measurements, appreciated
#82
Probably the difference depends on whether the cooler is standing off from the frame rail (bottom radiator support) or whether it is mounted flush against it... I relooked at your pics, yours and a few others are flush mount, I'm wondering how much difference this makes.
#83
*Result*
I just got home from about a 2 hour drive of city/country driving. I purchased a thermometer -non digital- to measure the power steering fluid temp. I have the frame rail cooler from Perma-Cool and have not cut slots in the air dam. The cooler sits behind the air dam, beneath the radiator. The hot temp was 170F.
#84
I temporarily installed an oil temp gauge just after the cooler before I took the car to the autocross a couple weekends ago. Temps were 130-150° under normal street driving on the way to and from the race. Daytime temperatures were about 100°+ with the heat index. The highest temp I saw while racing (I couldn't watch the gauge too much!) was about 200-210°. The course lasted 55-60 seconds, had 9 aggressive turns, and top speed was about 55-mph. After my runs, by the time I drove into the cool down lane and back around to the staging area, PSF temp dropped to around 170-180° when I parked it.
Take from it what you will, gentleman.
#87
Were you able to get some temperature readings? I will try to post a temp tomorrow after I arrive home from a one hour drive on a country road. I will also get a base temp before I start moving.
*Result*
*Result*
Where do you want readings from, just after the cooler?
#90
I'm sure you'll be fine without any cooler at all.....but you're not helping the pump last as long as it possibly can, thats all.
Heat kills everything...........
#91
No....just got my new tranny in this past weekend, car has been sitting on a lift for a long time. I'll try to do it tomorrow when I get it back to my friends shop, the fluid will be at max operating temp, under normal driving getting to his shop. Its about a 25 minute ride to his shop. Hopefully he has his laser temp gauge there.
#92
I was gonna hit the metal output port on the cooler with the laser? I'll hit the rubber return line right at the bottom of the reservoir too.
PM me a reminder tomorrow night. Again, I hope he has his laser at the shop.
#93
And pumps didn't last as long as they do these days. My pump is my 1998 original, I'm certain its because I got rid of that factory joke of a cooler and put an aftermarket one on.
#98
Harbor Freight...laser temp gauge....$15.00 But has terrible reviews.
Didn't want to buy one, but maybe I'l get this one for $25.00. GREAT reviews.
http://www.harborfreight.com/infrare...ter-93984.html
