running 160* thermostat at winter time made me loose coolant ?
I check coolant almost every 2 week, and recenrtly it getting really cold out side, I alway want to change to 180* for winter, but have not time atm. Anyway I note I loose half cup of coolant recently. mabe 4oz of coolant. How much coolant loose a year is consider normal ? i mean does coolant get low in winter time ? thanks
No, coolant should never ever go away if everything is sealed properly. I don't think I opened my radiator cap for a good 3 years straight when my car was brand new and bone stock for its first 3 years of being bone stock. It was 100% topped off.
I bet your starting to lose coolant out of the cap. You shouldn't take your radiator cap off that often. I'm NOT sure, but aren't we supposed to get a new cap each time we open it....according to the manual?
If I were you I would go get a new Stant cap with the pressure relief lever on it....they are great, and they cost like $3.50. Mine has been rock solid for like 5 years now.
Save the manuals!
I'd suggest not getting the Stant cap and going with a GM one. The original cap has a vacuum release (in addition to the pressure relief) which protects you from a vacuum build up that can crack the plastic parts of your radiator.
How many miles do you have on the car?
IDK about loosing coolant, sounds like either a leak (which you need to find) or head gasket.
As for the colder t stat, idk where you are from. Imo I wouldnt ever use a cooler t stat in winter. These engines are desinged to operate at least 190. This time of year my temp sometimes dip to 186 (just for a min) at highway speeds with the stock stat.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Im using just regular under 3 dollar car, that have no pressure release **** thing, it cost 7 dollar, but I just go with cheap under 3 dollar one, I just pop the cap this morning and saw coolant still full. Look good quality, but the guys above say it have vacum release and pressure release on gm cap. I dont want to keep using my stant cap and if it over pressure and crack my radiator.
. should I keep this under 3 dollar cap or get new gm one ?
The cap is ~18psi, the pressure leaving the radiator just pushes that cap open and releases the pressure..........I don't see how you can possibly have an overpressure situation that can cause a crack.....UNLESS you have a 25-30psi cap (or whatever) and the pressure cannot get pushed out.
As long as you have an 18 psi cap....you cannot build pressure much beyond 18 psi before the cap pushes open and spits out coollant into your overflow tank.......and you need a ton more than 18 psi to cause any issues in the system. 19psi doesn't crack anything.....I would guess it would have to go well into the 20's..........
Up to you....get the GM one if you want to.
Save the manuals!
I looked at the system and the only way I can think a vacuum can occur is if the overflow tube gets clogged and the coolant in the radiator contracts as it cools.
