Non- LS1 issue plz help
how many miles on the vehicle? also check for an lower intake leaking as those are notorious for them
i was going to change the water pump a few months ago when the car tried over heating, but after changing the upper/lower rad hose it worked perfectly fine.
Jack up the car on the front right side as as high as you can get it. Not sure if this car uses a bypass valve on the heater hoses, but just to be safe, blast the heat settings all on full blast. Start the car and get it just hot enough that you can still get the rad cap off. Massage the upper rad hose with force to try to burp the air out the rad cap hole.
Play with that for a while, then put the cap back on, let it pressurize, and see if you get any heat.
back flushing is easy to do just need a hose. disconnect the 2 heater hoses on the engine side, NOT the connections on the actually core and run a hose in the opposite direction of flow.
however i would try getting every bit of air out first like the other gents are saying.
I wouldn't go any farther until I backflushed the car... seen it happen before, very easy fix.
