Sponsored by: CARiD
trunion upgrade kit
Old Dec 9, 2010 | 07:04 PM
krazy8chevy's Avatar
Default trunion upgrade kit
Im pretty much in same spot as this guy
https://ls1tech.com/forums/generatio...n-upgrade.html
I too have a stock 99. I found the same little pieces of metal at tip of my drain plug also.. rocker arm and needle bearings too
Everyone keeps telling me pop valve covers pull the rockers start looking..
I just wana get a quote on all these parts. Whats it cost to fix something like this. Now theres no telling how long I drove the car like this but I started to hear a slight chatter sound around 2200-2800rpms never herd anything when the car is ideling. what all would I need
Old Dec 10, 2010 | 10:21 AM
Anybody?
Old Dec 10, 2010 | 07:51 PM
dam nobody???? well can someone moved this thread to where I'll get an answer
Old Dec 11, 2010 | 02:03 AM
joecar's Avatar
DIY option: the Comp Cams Trunion kit is about $135 or so, and takes about 4-5 hours or so to do all 16 rockers.
Other options: parts + labour.
Old Dec 13, 2010 | 11:35 AM
Nasty N8's Avatar
We offer complete rebuilt rockers with upgraded trunion kits installed. From $210
Old Dec 13, 2010 | 12:04 PM
djfury05's Avatar
Damn 4-5 hrs lol.. it took me 30 minutes to remove the rockers from the car, remove the old trunions, and reinstall the new ones. 2 16mm sockets, patience, and a hammer did the trick.
Old Dec 13, 2010 | 04:00 PM
joecar's Avatar
So you spent no more than 1 minute 52 seconds per rocker...? That's quite a talent.
If he was to take his car to a shop they would charge him for a lot more than 30 minutes labor.
Old Dec 14, 2010 | 08:14 AM
01ssreda4's Avatar
The internet is full of super mechanics.
Old Dec 14, 2010 | 09:35 AM
djfury05's Avatar
If you want to send me your rockers to do the trunion on ill video tape it happening.. I followed bene's write up except I didn't use a vice. I used an old head bolt with the rocker sitting on top of a socket large enough to catch the old trunions. Hit the rocker about 2 times with a hammer on the head of the head bolt directly on the old trunion and it'll pop out just like it says in the write up. Then I did the next steps differently than Bene. I grabbed 2 bearings and a trunion and loosely set them in the rocker. Next put the rocker on top of a 16mm socket and lightly hit it with the hammer until the bearing gets set about flush with the rocker. Then grab another 16mm socket and hit the the bearing that isn't pushed in yet and it will push BOTH bearings further into the rocker. It literally took the time I said it took.
Old Dec 18, 2010 | 12:53 PM
Whats brand of rockers should I use? again car is stock
This is so tempting but dunno if I wana chance it on rebuilt rockers
Wheres Bene's write up
