Turn Signal Issues
It sounds like either the front or rear left side turn signal bulb is blown.
Turn the key to accessory and play with the turn signals, It should blink on the right side but the left side probably has a blown bulb.
If thats the case, then the lever is not bad. The shop is just guessing and making you buy parts.
I 'd swap the right side bulbs (front and rear) to the left side to see if any thing changes.
(Put some dialectic grease on the bulb's base when you insert 'em into the socket also).
If the right side bulbs don't show any positive change then a socket might be bad.
Did you also swap the bulb on the left front from the right side?
If the bulb from front right side doesn't work that means the front left side socket needs to rebuilt/ replaced.
I'm not sure if '93 fbodies had parking lights, if yes , do your small corner bulbs work?
Its the small 194 LED bulb.
ps: my passenger side signal bulb blew out in the car wash today, thanks for rubbin this off on me too.
If all the lights work properly with the parking lights on and then with the hazzards on, that confirms your bulbs and sockets are good. The fact that the bulbs light solid confirms your switch is good. The only thing left is the flasher.
And Bad 408 Vert, that sucks about your light, I hope yours is easier to fix than mine has been. haha. And speaking of car washes, I dont even know if I can take mine in a car wash because of the opti... I'm still learning what I can and can't do with that thing.
