97 TA radio, windows, wipers won't shut off. killing battery!!! FIXED
97 Trans Am with factory keyless entry. When I turn the car off, take and keys out of the ignition and open either door, the powers stays on to the radio, wipers, windows, and locks. Normally when you open either door it should cut power to all of that but it isn't. I thought it might be the switch in the door jam but the chances of both being bad is low. It has an aftermarket radio in it but it was doing this before that radio was installed. If it sits for more than a day, the battery is dead. I don't know where to go from here. Any suggestions?
With the key in the ignition I get the "ding" only when the driver side is open. When the passenger side is open nothing.
Also, when I turn the key to the first click, I get no lights on the dash. When I go to the last click before starting I get all of my dash lights except for the security light. I dont know if that is related though. The PS window also rolls up and down "alot" slower than the driver side does.
I bought the car with the problem not thinking it was something major.
The dome light never goes out. It comes on when you open the doors but never times out. Also noticed that I can turn the headlights on without the key in the ignition. Also have power to the fog lights.
I am leaning toward the electrical part of the ignition switch.
I had a somewhat similar problem. I bought the car with an aftermarket radio and later removed it. I installed a factory radio and it began to drain the battery. I thought it was a bad radio so I installed another one and had the same problem. It turns out it was the factory amp that is the problem. I reinstalled the aftermarket radio, which by passes the amp, and has never drained the battery.
Ok, the red junction box next to the battery has several wires from the harness that go to it. I noticed that one of the wires had tape on it. I un taped it and the wire is broken. I hooked everything back up minus that one broken wire and it killed power to everything that was staying on. What are all of those wires?
Save the manuals!
Pic?
Looks more and more like there is some damage or incorrect wiring in the car. Your cut wire points to maybe a shade tree mechanic doing some funky stuff to it in the past? Have you taken a look under the dash at the wiring? Anything wierd there or an aftermarket radio system?
Yes, it does have an aftermarket radio. I have looked at the BCM, all under the dash and everything looks ok. I don't see any sign on things being cut into or butchered. The guy I bought it from said that it did this before he installed the aftermarket radio. If the ignition sw wasn't so hard to get out, I would tackle that but I am trying to weed out the easy stuff first.
Save the manuals!
If they guy you bought it from was so smart, why didn't he fix this issue?
![](http://images.ibsrv.net/ibsrv/res/src:www.ls1tech.com/get/forums/images/smilies/LS1Tech/gr_confused.gif)
I'd think if the door doesn't chime when your key is out, the switch is fine. Also, if the dash warning lights come on when you turn the ignition one click, that would point to it being fine also.
I took the NEG battery cable off and put a test light to the NEG side. The BCM (on the pass side behind the glove box) began to click. I unplugged the large blue harness first. It stopped clicking but then my headlight motors started clicking. I unplugged the headlights and plugged the blue connector back it. The BCM started clicking once again. I unplugged the large blue connector again and left the two smaller ones in the BCM. The clicking stopped but the test light still had a very faint signal. I unplugged every plug in the BCM and still had a very faint signal to my test light.
What is my next step?
It turns out it was the aftermarket radio. The guy I bought it from said that it had these problems before he installed the radio but failed to tell me that he took out a different aftermarket radio and installed another one incorrectly. Re-wired everything correctly and problem solved...
