New radiator, water boiling out of coolant resivor
Discovered a crack in the plastic edge of my radiator last week and ordered a factory style replacement radiator off of Summit. Built just like the stock one. After installing the new one, I had my dad put water in the radiator while I went inside to grab my wallet and after filling it up I took it around the block a few times, temp gauge stayed just below 210 like normal. When I pulled in the driveway, I got out leaving the engine running to look under and make sure there weren't any leaks from the hoses and literally 10 seconds after not seeing anything, water starts pouring from the passenger side. Water was boiling out of the coolant resivor. My question is, is this from maybe putting too much water in the radiator, or do I have a problem? I can't tell you how much was put in since I did not do it myself.
No he didn't put any antifreeze cause I was planning on flushing it all out once I got back, and I went and looked at the cap and it is extremely loose. Air could definitely get in just by looking at. The new radiator didn't come with a new cap, Im still using the stock one.
Get a new cap for sure, especially if you got a new radiator. 18 psi cap.....
I use a Stant cap with the pressure relief lever on it......been rock solid for 5+ years. $3.00
OH....and you must fill the radiator up all the way, the system must be 100% topped off, zero space in the radiator. Air being in there is bad.
You should let it idle with the cap off, and wait till you see the coolant start to flow in the filler neck (t-stat has opened). If the level drops down IMMEDIATELY top it off, and put the cap on. Thats how you make sure all the air is out of the system.
It gets a bit colder up where you are in Florida, but down here in South Florida....I've always used a half jug of Dexcool and the rest hose water. Works perfect, my engine runs sick cool......
You might want to use a whole jug because you get much colder in winter than we do.
Just flushed the whole thing out and it still started boiling out of the resivor, temp gauge remains at 210 however and my fans are NOT coming on. This sucks I have headers and a new exhaust system just sitting in my room and now I have to put up with this...
just out of curiosity..did you accidentally switch the lines that go from the resevoir to the rad. and the line that comes from the engine crossover pipe to the rad..the resevoir line goes to the top fitting just under the cap, the crossover line goes on the lower fitting..i had them switched (was puttin my ls1 back together in the dark, and in a hurry) switched these 2 hoses and it did the exact same thing as yours is.
