Power steering fluid dumped
See pics. The connection in question is circled. The other pic is provided for the general location.
Question:
Is this hose supposed to be connected or is it supposed to be plugged? I have it connected but considering that it looks like it connects to the radiator??? I want to be sure.
Thanks.
In the end though, yes, it's supposed to be connected and should get you running again just nicely.
You may want to put a screw clamp on it to make sure it holds tight. The old spring clip may be getting weak.
elthesh: I definitely don't want that. Thanks for the advice.
Please wssix99, I'm paranoid enough. But I think I will put that spring clamp on.
cowboysfan: the hose seems to be in good shape. I'm going with wssix99's theory.
As for the coolant stick it's pretty dirty and crusty. Does that mean anything?
So mike you just removed it?
If you remove the stock cooler, you should replace it with an aftermarket one. The cooling will help the seals on your PS pump last longer and also help keep you from boiling over the tank: https://ls1tech.com/forums/general-m...g-success.html
if you find oil in there as in power steering fluid then it would mean something. But you can have a clean overflow bottle and the cooling system as in radiator and block contaminated. That contamination (oil) would only make it into the overflow bottle when the engine gets hot and coolant pushes into the overflow resevoir, which may or may not happen.
The best way to tell is open the drain valve on the bottom of the radiator and drain a quart or so of coolant into a glass and check it out for contamination.
All overflow tanks will get crusty and nasty, and that does not mean that's what it's like inside the radiator.
At the least your overflow tank is cruddy, so pull the battery out and pull out the overflow tank and clean it out using the garden hose. It's easy, then refill it with fresh 50/50 coolant. And being a 1999, if the coolant has never been changed or you don't know, now is a good time to do it. After all it's 5 year coolant at best and you're 10+ on it.
many cars came from the factory without that power steering cooler. That cooler generally is not worth it, so if you're putting work in on the car you might consider just bypassing that cooler for the power steering- you have to leave it there to connect the radiator hoses, then if it fails you'll have a more harmless coolant leak onto the ground that you'll more easily notice and can take care of when that happens.
True - until 1999 when too many P/S pumps were biting the dust and GM started putting them in all V8's. http://www.gmhightechperformance.com...all/index.html
The cooler is not required for the car to run, but it will help the P/S pump last longer. So, the "worth" of it is probably subjective.
yeah if the car is in good condition, but it really isn't in good condition since the guy is posting. and it's a 99, and he said he never added any coolant but he also didn't say he knows the cooling system is topped off and does not have any air in it.
in checking the cooling system, i wouldn't base my conclusion on the coolant is fine by solely looking at coolant in the overflow tank. If the radiator cap is all crudded up, it might also be possible that coolant isn't flowing into the overflow tank when it heats up, assuming the system is full with no air. neither of which we know.
