2001 Will not turn over
Also, the first thing to do is check all your fuses, never underestimate the simple stuff.
Did a few searches and quite a few people had similar probs; one fix was to swap the starter and ignition relays. I did that and the car started right up. So I went ahead and bought 2 new relays (both the starter and ignition are the same p/n) and kept the old starter relay as a spare. The new ignition relay seems to be the fix; the good thing is it's only a $12 part and it took a minute to replace.
You figured it out right there. You aren't getting good enough fuel pressure to start the car. That's why when you assist it with ether/starting fluid it fires up and stays running. It can take quite a bit of volume/pressure to start the car.
To verify, next time you go to start the car, turn the key forward to the ON position (DON'T ATTEMPT TO CRANK IT OVER), just key it ON 5 or 6 times. This will prime the fuel pump multiple times and get fuel up to the engine. After doing that 5 or 6 times, go ahead and crank the engine over. If it starts right away, you know your fuel pump is on its last leg.
