Help!!
Took me a week to find it, afterwards ran like a champ Trending Topics
Does this happen when you are up to operating temp also?
Rising rpm's....vacuum leak or bad IAC valve. Thats the ONLY two ways an engine can rev with your foot off the throttle pedal. Air must somehow get to the cylinders for an engine to rev.
Bogging.....many things can cause that though. Since your engine finally catches after you have the pedal halfway down and the car takes off....
---This is NOT a problem with air delivery---
Could be:
-Failing Crank Shaft Position sensor
-Failing Cam Shaft Position sensor (I believe this sensor has more to do with fuel)
-Broken crank trigger (IIRC, can affect fuel delivery)
-Ignition not providing the coils with power
-failing fuel pump
-Big clog in the fuel filter
You may have two unrelated issues to deal with.
