No Prime From Fuel Pump
I turn the key, i hear clicking from the relay but no buzzing sound that i used to hear from the fuel pump priming. First things first, i checked fuses and relays and swapped with known good ones, nothing. Checked the schrader valve, not even a hint of pressure. Where do i go from here? Thanks guys!
The misfire seems to come apparent the longer it idles, it also while driving, will flash sometimes and then just stay steady on the SES light, it feels that the misfire is constant for the most part however.
The misfire will shake the car and the shifter pretty noticably and also stumble and become more obvious under acceleration, it will bog down and shake a bit more. The engine RPM's aren't very affected by this misfire however, just mainly you can hear it and it feels off balence
I would need to see the flowchart and code description from the service manual for a p0200. That is not a very common code and in my four years as a GM tech have never had one set. I would start with the fuel problem since we know that has a problem.
I pulled the plugs (after i had ran it, and they look just like i put them in yesterday, no buildup or being wet.
I don't know how long the system is supposed to stay pressurized, if read people with different cars saying theirs held 60 for a week, some saying it went to 0 in about 5-10 seconds of turning the car of, etc. Could a leaky injector also cause the fuel to lose pressure after being off? The running and idle pressure stay constant at 58lbs.
Thanks for all the help so far Turbopig!!
