Sponsored by: CARiD
firebird engine running too fast!
Old May 29, 2011 | 01:43 AM
fawnstar's Avatar
Default firebird engine running too fast!
I start my engine and it is running very fast. I heard a pop so i turned the engine off. I started it back up still running fast put it in reverse and it spead off backwards. On the street I had to stop far away from cars because the car would come to complete stop then try to go again with my foot on the brake. Please tell me what is happening.
Old May 29, 2011 | 03:03 AM
green manalishi's Avatar
prob need a little more info here bro.....what bird, engine, etc do you have?
funny story....i had a dirt dobber build a nest near my throttle cable lever once. it got stuck and every time i turned the car on it was like the gas pedal was floored. popped the hood and saw it immediately.
Old May 29, 2011 | 06:16 AM
HWI's Avatar
HWI
By running fast, do you mean the idle rpm's are high? If so, what's it idling at? Check to see if your throttle cable or throttle body blade is sticking.
Old May 29, 2011 | 06:30 PM
tonygarcia1990's Avatar
could be a vacuum leak
Old May 30, 2011 | 11:41 AM
patSS/00's Avatar
Could be IAC valve stuck open due to carbon buildup, or just worn out. Easy to clean/replace.
Old May 30, 2011 | 05:26 PM
garygnu's Avatar
also check the TPS sensor.I bet its the IAC .did you do any work on the intake?
Old May 31, 2011 | 04:28 AM
lovin myls1's Avatar
If a cacuum leak is too large the idle control system can't compensate enough so car idles too fast- i vote leak - one of those small hoses -gotta check em all!
Old May 31, 2011 | 04:30 AM
baalic's Avatar
If it's a v6 it's drive by wire and could be a throttle position sensor.. My brother had a similar problem but in the opposite.. Car would start but not move... Lol
