**Changed my differential oil today... PICS
#42
Welll it seems I might reconsider the whole synthetic oil thing. What 02form makes sense.
Just can't see why GM would recommend a synthetic if a non syn is best for the rear.
On a different note, my rear end is leaking!! wtf
Im pretty sure its the shitty diff cover, so i ordered a new one. and im gonna replace the oil again next week.
What a waste of oil. FML and money
#43
If you didn't use a torque wrench to tighten the bolts to spec, and just wrenched 'em down, luck has nothing to do with it.
#45
#47
I have seen a swap to a synthetic and within a week bearing howl ultimately leading to a complete rebuild.....And, every rear I have rebuilt i have recommended dino oil to the owners and they are all living healthy....Coincidence? Maybe, maybe not.
#51
pssst I had a 89 Camaro with over 200k on the car REAR never touched except to change the CHEAPEST regular gear oil every 50k.
#52
That's MISTER MODERATOR
I like everything you've said about gear lubricants and it all makes sense.
As you pointed out the disadvantages to using syth gear lubes (and I agree with what you've said) I'd like to know which version of Redline gear lube you're using.
This is something that you can add to this thread.
http://www.redlineoil.com/Products.aspx?pcid=4
