Sponsored by: CARiD
changing oil and found coolant ?!?!?!?
Old Oct 3, 2011 | 09:42 AM
jaysan's Avatar
Default changing oil and found coolant ?!?!?!?
I checked my coolant levels and they are good . Is this something I should be concerned about ?
Old Oct 3, 2011 | 09:59 AM
Deviant LS1's Avatar
Yes, you should be worried about leaking coolant. Take a look and find out where it's coming from. I would guess it's coming down from the water pump.
Old Oct 3, 2011 | 10:01 AM
mai krod's Avatar
Yes you should definitely be concerned. My guess would also be water pump. good luck
Old Nov 10, 2011 | 06:09 PM
jaysan's Avatar
So I pulled my water pump and I have a question about the gaskets . Which do I use ? Also one of the square rings is missing
Old Nov 10, 2011 | 06:11 PM
jaysan's Avatar
The one on the left is what came off the car . The one on the right is what came with the water pump . You can see there is an o ring but it is missing the square ring . Which gasket do I use ? and if I should use the metal one where do I get the square ring ?
Old Nov 10, 2011 | 07:20 PM
rnl35thss's Avatar
I prefer the style that came with the water pump. The fact that the square part is gone from the original gasket probably has a lot to do with your leak. I've seen more of those gaskets fail than the pumps themselves. If you want the OE style gasket, order some fel-pros, there is no such thing as putting the old gasket back together.
Old Nov 10, 2011 | 08:20 PM
jaysan's Avatar
So just buy some fel pros ? Well the other gasket has both pieces but the other is missing the square one . I was thinking about buying one fel pro and reusing the factory one with a square and circle piece. Unless that is a bad idea ...
Old Nov 10, 2011 | 09:06 PM
joecar's Avatar
Bad idea...
get two new metal ones (like the left one in your pic)... they now have the rubber/silicone circle/square molded to the metal.
The GM ones are good and are cheaply priced.
Old Nov 10, 2011 | 10:47 PM
jaysan's Avatar
I just bought 2 new fel pros from vato zone
Old Nov 10, 2011 | 10:59 PM
jaysan's Avatar
LS1 tech approved ?
Old Nov 10, 2011 | 11:50 PM
VandykeT/A's Avatar
Looks good to me
Old Nov 11, 2011 | 03:23 PM
jaysan's Avatar
**** that sucked . It took 2 hours . Future members beware of the bolt in front of the pulley on the drivers side
Old Nov 11, 2011 | 03:29 PM
14k's Avatar
14k
thats about how long it to me to change mine. well sorta.. i ran to the store to get a new belt and antifreeze after the pump was off then i cleans the thermostat.. lol first time too. did the problem get fixed?
Old Nov 11, 2011 | 10:09 PM
jaysan's Avatar
Don't know yet but I will update later
