Sponsored by: CARiD
Is my cat going bad?
Old Oct 5, 2011 | 08:40 AM
VinR1's Avatar
Default Is my cat going bad?
just curious - I have headers and ORY i'll be putting on soon but im still wondering if this is the problem
Ive had the car a year (93 TA) but only drive it maybe once a week. When cold, it sometimes takes a few extra spins of the starter to get it to crank...could be a fuel filter also Im guessing. The biggest problem is heat - when hot, there is a heatwave pouring out from the cat. So much, that my passengers complain when getting in/out of the car. You cant stand next to the passenger side without your feet feeling like theyre severely sunburnt. After a few minutes the console is very hot and the shifter and e-brake are too hot to touch.
Like I said, its coming off anyway, just wondering for future reference
Old Oct 5, 2011 | 04:53 PM
Zlow28's Avatar
try to take the temp from both sides of the cat. If the side going to the engine is a lot hotter than the side leading towards the exhaust, then the cat might be clogged. But there shouldnt be any reason for the cat to cause starting problems.
Old Oct 5, 2011 | 05:08 PM
jclz28's Avatar
Borrow or buy an IR temp gauge (they are like $40) and measure the temp of the cats. If one is running hotter than the other (more than 20% hotter), and you are sure you dont have a fuel imbalance or stuck injector on one side, its probably your Cat being partially clogged. I would not wait, because Ive seen them melt wiring and cause car fires. BTW, the IR temp gauge (looks like a gun) is really useful for other things, so don't think its wasted money. (you can check your brakes for stuck calipers, check your hubs for bad bearings, check or AC components, all by measuring temperatures etc)
Old Oct 5, 2011 | 07:09 PM
VinR1's Avatar
Its only got the one cat under the hump
Old Oct 6, 2011 | 09:28 AM
wssix99's Avatar
Save the manuals!
It's 100% normal for cats to get this hot. They get hot because exhaust goes through them, not because of their function.
Look at the heat shield (post pics if you can) and I'll bet you'll find the problem.
Old Oct 7, 2011 | 11:12 AM
VinR1's Avatar
What am I looking for with the heat shield?
Old Oct 8, 2011 | 10:00 AM
wssix99's Avatar
Save the manuals!
Make sure its there, that it isn't loose, and that it isn't physically contacting the exhaust pipe.
I suppose a broken substrate in the cat would cause pressure problems on starting, but wouldn't think that would make it hotter. If anything, less gas flowing through should make it cooler.
Old Oct 8, 2011 | 09:45 PM
FiredUpZ28's Avatar
You'll more than likely have a MIL as well if the cat is bad. I agree, I bet a heat shield is missing.
