why are our coolant level sensors 80 bucks through gm?
Save the manuals!
Sloshing and blow-outs are classic blown head gasket = not good.
"A coolant recovery reservoir is connected to the radiator to recover engine coolant displaced by expansion. As the engine cools, the engine coolant is drawn back into the radiator by vacuum."
If yours is always dry, you're low on coolant. The reservoir is designed to keep air out of the radiator.
Yes, it should. Read the GM manual.
I'd like to see that process actually take place. I'd like to see how coolant can flow back into the radiator with the suction from cooling pulls the radiator cap seal on harder and harder.........the suction can't over-come itself. Either the cap will be too tight (from suction) to let coolant get in or the seal would have to get sucked into the radiator.
I just don't see it happening. My coolant is always topped off where when I check it the cap comes off wet. I can certainly see coolant leaving the radiator from an over-pressure, but going back in......maybe it happens, but that defies physics in a way. More vacuum pull, better the seal.
Radiator caps have a pressure relief and vacuum relief valve. It uses a heavy spring for the pressure relief, allowing pressure over 18 psi to push its way back into the overflow tank. When there is a vacuum drawn by the cooling system, the vacuum relief valve allows coolant to be drawn from the reservoir.
This is a very well known design for radiator caps, it's been around for years. I really don't care what you say works for you. If it does, that's great. But that's not how the system was designed to work.
