Can someone check my plugs I pulled? Pics.
When I changed my plugs they looked like this (the picture is mirrored to reflect the cylinder it came out of if you were looking at the engine from the front of the car):
The plugs from the two forward most cylinders on the passenger side look the most concerning. The car appears to be running just fine with the new plugs in.
Is that carbon tracking on that plug on the bottom left? If it is you will need to replace that wire too with the new plug or it may start misfiring on that
cylinder, while your at it you might as well replace all eight wires so as not to have a problem in the future.
Chris
Chris
