All firebird and trans am owners...
On a trans am, when you press the lock and unlock button on your keyless entry remote, do the headlights flip up and down every time you press it? because I just programmed a keyless entry remote with a 2001 ws6 and it does that for some reason
The Scammer Hammer
My TA would do this... BEFORE I replaced the gears in the headlights with the brass units from Rodney Dickman. Just google him.
As skopers3 stated, for some weird reason, when the headlight gears are on their way out, they pop up when you lock or unlock. Used to hate it.... quite embarrassing.
Right after I swapped the gears out, it stopped and never did it again. Just the parking lights and fogs woiuld flash.
The Scammer Hammer
I have since have sold the car, but they were in for a year and a half and never had another issue. Quiet, too. Dickman's kit seriously is the ****. The expoxy he gives you works great with the plastic, as well as the extra brace. I simply think it's the best gear kit on the market. Money WELL spent.
Beautiful car, BTW.
Beautiful car, BTW.
The Scammer Hammer
^^ That's the BIGGEST thing right there. Make sure your motor housing is SECURE and tight. Dickman talks about this on his website:
http://rodneydickman.com/n113.html
Save the manuals!
There are two metal stops. (From the factory, they came with plastic bumpers on them.) Check the stops and make sure the arm that connects to the motor is contacting them. If the arms don't hit the stops, then you'll still get the behavior.
Bent tabs or if the arm is not pressed on to the motor shaft correctly, the arm won't make contact with the stops.
