Sponsored by: CARiD
Flickering lights on startup?
Old Feb 18, 2012 | 09:00 PM
01BlueSS1995's Avatar
Default Flickering lights on startup?
after i crank my car,the lights, interior and exterior, go crazy for the first minute or so. they never go completely out though. any ideas? bad ground? lights also will flicker on and off on the rearview long after automatic timer has went off, dont know enough electrical to even have a clue.. help?
Last edited by 01BlueSS1995; Feb 18, 2012 at 11:07 PM. Reason: wrong section..... mod move?
Old Feb 19, 2012 | 08:47 AM
wssix99's Avatar
Save the manuals!
What does your voltage gauge do while all this is going on?
Old Feb 19, 2012 | 10:40 AM
fluctuates from about 9 or 10to 13-16ish.. Alternator going out?
Old Feb 19, 2012 | 09:44 PM
HumanNipple's Avatar
alternator
Old Feb 19, 2012 | 10:49 PM
Floorman279's Avatar
yea its your alternator man......on my 98, mine was flickering bad.....replaced it with this 145 amp alt from advanced andguess what, my gauge read just a little higher and no more flickering......they have a 15% off deal til march 3rd
http://shop.advanceautoparts.com/web...1_R|GRPALTSAMS
its a truck alternator and worker great
Old Feb 20, 2012 | 12:04 AM
Ruthless909's Avatar
I've got the exact issue with my lights flickering for the first minute upon start up
thanks for posting this.
Old Feb 22, 2012 | 03:41 AM
AiDRocks's Avatar
Is this a plug and play? Any other parts needed?
Old Feb 22, 2012 | 06:20 AM
RealLiveMD's Avatar
alternators are plug and play. I'm getting mine rebuilt now. Remove back screw first. Then loosen the front 3 bolts. slide the alternater and pulley bracket forward about an inch. Use Left hand to feel for the clip. R hand with small screw driver to flip the lip off the red wire plug. pull alternater and pulley off. Takes 20 min. Reverse order and drive away.
Old Mar 3, 2012 | 09:13 AM
sala0164's Avatar
Have the exact same issue on my 02 35th, but the voltage gauge doesnt move from past 13 volts...if you give it a little gas...it flickers bad...
Any thoughts on my particular issue...
Just got the car in January
Old Mar 4, 2012 | 03:55 PM
same problem, except mine is starting to do it even after it warms up a bit.. last night they wouldnt stop flickering..
