Sponsored by: CARiD
Severe engine overheating problem!!!!
Old Mar 6, 2012 | 11:52 AM
GormanRacingZ28's Avatar
Default Severe engine overheating problem!!!!
I have 2002 Camaro Z28, I'm having some really bad overheating issues with it, just put new coolant in and burped the system. I am thinking the T Stat is bad, what is a good way to check this, also I have gargling noises in the cooling system when I turn it off. Air? Lower hose is cold after driving and upper is super hot.
Old Mar 6, 2012 | 12:51 PM
bigboykilroy's Avatar
did you drain the coolant to begin with? it doesnt seem like you have it filled all the way.
Old Mar 6, 2012 | 02:07 PM
Yeah I drained the entire system, topped off the radiator and the reservoir, I have no leaks. But when I try and burp the system, it will not reach 210, and the coolant just keeps flowing over. Thermostat?
Old Mar 6, 2012 | 02:40 PM
Can I take the thermostat out and run the car, also is it smart to take the crossover tube to the throttle body off and run the car?
Old Mar 6, 2012 | 03:18 PM
PowellSixO's Avatar
T-stats usually fail in the open position, but it is possible to fail closed. You can pull the t-stat out and run the car for a couple minutes to see if your water pump is working, but I wouldn't run my vehicle without a t-stat for long. Have you checked the water pump yet?
Old Mar 6, 2012 | 03:28 PM
Thanks bro, no I haven't checked it out yet. No a good way of checking it?
Old Mar 6, 2012 | 10:53 PM
chrisfrost's Avatar
Yes , that t-stat is stuck ,,,,,,,,,,,,,not worth messing with ,,,,,,just repace it and get the air out and You'll be good 2 go .
Old Mar 6, 2012 | 11:31 PM
91sonomast's Avatar
Yeah if your top hose is hot as hell and the bottom is cold, t-stat.
