Window regulator
Well, I pulled into the garage yesterday and the passenger window just fell into the door (95 firebird). I pulled the panel off and the 4 1/4" rivets that held the regulator in place had been pulled through the door. I've got the regulator out of the door and removed the old rivets now I need to reinstall but I don't have access to a rivet gun that will do 1/4.
My question:
Is it possible to bolt it in?
I could buy one from oreilly's/autozone but don't really want to blow $40 on something I will use once in my life. It looks like I can get bolt's in there I just don't know if they are going to interfere with the regulator's movement.
These special rivets can be had from GM, maybe other sources as well. I'm sure someone that has replaced one of these can confirm where to buy the correct rivet. This is part of the reason why I don't believe in removing the regulators on these cars just to replace the motor. Someone may have already removed and (incorrectly) reinstalled yours, causing this issue. If that's the case, then you'll need to do something to correct the enlarged hole left behind.
I just got back from the hardware store with nuts, bolts, and a hand full of washers and gonna try to rig this puppy up. Seems like it will work if I can get the nut started on the bolt from inside the door.
Hopefully I can get it to stay securely with bolts, actually going up and down will be a bonus but for right now I need to get it out of the garage so my GF can park in there.
https://ls1tech.com/forums/general-m...-included.html
Used the two washers on the outside of the plate for each of the two bolts closest to the door hinge (probably should have gotten 1/2" long bolts but this worked) to keep the bolts from obstructing the path of the regulator gear.
All in all it took me about 2.5 hour to reinstall everything by myself (retracking the rollers alone was a PITA)
I still have enough sheet metal to do the driver's side door since it is slowing and rattles if closed with window down.
I like to be thorough like that.
