how do you force the ac compresser on???
you're copmpressor is not turning on probably cause its low on freon.so if you just "jump" it on,it still wont cool.
get some gauges and see what the freon pressure is.i bet its low.if so just add a can or so and the compressor will turn on.(if thats the case)
I wouldn't waste your time or money trying to put refrigerant in yourself. You have no way of knowing how much is in there and even if it's blowing cold, if the charge is low your compressor may not be getting lubed properly. Too much will make your pressure way too high.
Try jumping the switch and let us know if the compressor comes on. don't run it like that too long but for a few seconds to see if it gets cold. The big line coming out of the evaporator should start getting cold pretty quick.
If it gets cold you may just need a pressure switch. If the compressor comes on but it doesn't get cold then you need to have it recharged and it really needs to be done with the right equipment by someone that knows how to use it
