Engine light code ????
IMO - Starting with the most expensive repair without checking the other inexpensive (but less likely causes) isn't the best way to go.
The choice is yours.
If you replace it, go with an OEM unit - aftermarket ones are not usually as efficient and the light will likely remain.
