Sponsored by: CARiD
oil light
Old Nov 17, 2012 | 10:42 PM
xenergyx's Avatar
Default oil light
Ive replaced my oil and oil filter a few weeks ago in my 02 T/A and attempted to do the oil reset but to no avail this was the first time Ive done it myself usually I just take it to a shop and its fine but now the oil light comes on every time I fire the car up and goes out after about 20 mins. Did I do something wrong or forget to do something or is my car just being picky?
Old Nov 17, 2012 | 11:29 PM
PhoenixFBody's Avatar
Did you try holding the oil reset button with the key OFF and then turning to ON position while holding the button? Most Chevy are 5 pumps to the pedal but not true for F-Bodies...
Old Nov 18, 2012 | 01:21 AM
ghardester's Avatar
Turn your ignition key to the ON position, without starting the car, just leave the key turned to On.
Press the gas pedal to the floor 3 times. Turn the key back off.
Then start your car like normal.
This is the best way to reset the oil light.
Old Nov 18, 2012 | 01:34 AM
baalic's Avatar
According to the book, turn the key on while holding the button, the oil light will
Start flashing, turn car off then back on... I've tried this push the pedal down thing before, and it never works.
Old Nov 18, 2012 | 08:33 AM
If anyone wants them, I have Service Manuals for 1998-2002 Firebird/Trans Am in PDF format. No where does it say use the pedal.
Old Nov 19, 2012 | 12:06 PM
ghardester's Avatar
Well then here are a few other sources, and there are dozens of other threads listing the same solution:
https://ls1tech.com/forums/pontiac-g...oil-light.html
https://ls1tech.com/forums/general-m...-start-up.html
https://ls1tech.com/forums/general-m...ight-help.html
https://ls1tech.com/forums/general-m...oil-light.html
https://ls1tech.com/forums/generatio...oil-light.html
Old Nov 19, 2012 | 11:09 PM
My Source... GM
1999 Service Manual
How to Reset the Oil Change Light
After changing the engine oil, the system must be reset.
With the ignition key in RUN with the engine turned off,
push the TRIP/OIL RESET button located on the
instrument panel for 12 seconds. The OIL CHANGE light
will start to flash to confirm that the system is reset. The
reset is complete when the OIL CHANGE light goes out.
2000 Service Manual
1. Turn the ignition key to RUN and with the engine
turned off.
2. Push the TRIP/OIL RESET button located on the
light will start to flash to confirm that the system is
reset. The reset is complete when the OIL CHANGE
light goes out.
2001 Service Manual
1. Turn the ignition key to RUN with the engine
turned off.
light goes out.
2002 Service Manual
The GM Oil Life System calculates when to
change your engine oil and filter based on vehicle use.
Anytime your oil is changed, reset the system so it
can calculate when the next oil change is required. If a
situation occurs where you change your oil prior to a
OIL CHANGE light being turned on, reset the system.
turned off.
2. Press the TRIP/OIL RESET button located on the
light goes out.
I think my sources are more credible because they are not from the internet...
Old Nov 19, 2012 | 11:14 PM
baalic's Avatar
^^ what that guy says, I have the books to a 2002 bird and 2002 camaro, that's the EXACT wording... Gas pedal method never worked I tried it even though I knew the right way just to see if it worked.... It did not.
Old Nov 20, 2012 | 03:49 PM
1_MEANZ28's Avatar
i just took mine off..key fowrd pumped the gas 5 times ,didi it 2 times exactly the same,,its gone..its a 99
Old Nov 20, 2012 | 07:19 PM
Thats interesting. I would still stick with the right way it is done, but if it works and doesn't waste any time, then do whatever gets the job done. It is just weird that the procedure works when its not officially mentioned.
Old Nov 21, 2012 | 02:21 PM
ghardester's Avatar
And another current thread in this very forum, with advice from a moderator.
https://ls1tech.com/forums/general-m...ht-coming.html
Old Nov 22, 2012 | 10:35 AM
I will be trying this method next time it comes on. I find it interesting that its a "working method" and not made official in the service manual. You can go ahead and look up yet another thread, but I will most likely want to experience this by doing it myself. Thanks.
Old Nov 22, 2012 | 12:27 PM
1_MEANZ28's Avatar
yea a buddy of mine tolds me it and it worked fine..try next time
Old Nov 22, 2012 | 02:27 PM
baalic's Avatar
Does not work on any of the 3 of my 2002's.
