O2 Sensors
I have not noticed anything change in engine performance or gas mileage. The only reason why I'm really concerned is that I need to pass an emissions test and won't be able to with this code.
Before I purchase a new O2 sensor, I'm going to try and switch the O2 sensor to the drive side to see if the code follows to the other side.
I know this has been covered a lot, but what I need to know is which front O2 sensor should I get? I have SLP LT and ORY. I know of the stories between Bosch, Denso etc. I was thinking of purchasing NGK because they're 10% off at a near by store.
I have read the the Corvette rear O2 sensor is good for F-Body's? So to clarify... I can use a REAR Corvette O2 for the FRONT in an F-Body? In this scenario, will I need an extension or will the Corvette sensor wire be long enough to fit in my headers?
Thanks!
Also, I am STILL confused as the the BRAND of Vette O2s everyone is always suggesting, or does this mean to just get the GM, or Delcos, which I take for granted are repackaged Densos????
