How to keep Firebird headlights permanently up?
I'm wanting to keep the headlights up for a couple months with the least amount of effort ( I would like to not cut the wire on the relay and have to solder it later.)
Can't I just take the gear out but keep the thing that spins the gears in? (so basically it will try to spin but obviously a gear wont be there)
Or is there an even easier way?
Thanks any input is appreciated.
You'll need to disable the motor electrically. I don't have a diagram in front of me, but the easiest way would be to find the fuse that powers the motors, run the headlights up then pull the fuse. If you take the gear out the headlight won't stay up by itself.
Save the manuals!
First off, this will kill your mileage. I loose 1-2 mpg with my lights up on the highway.
To disable the motor, unplug it, remove the terminal lock on the motor plug, and then use a paper clip to remove the red motor wire. Be sure to tape up the connector and bare terminal to prevent corrosion.
No need to pull a fuse - Once the lights are "up" - simply disconnect the two pin electrical connector on the side of the two headlight motors - easy!
