Sponsored by: CARiD
Steering Column and Turn Signal Switch Problems!!
Old Sep 4, 2013 | 04:21 PM
96ss1664's Avatar
Default Steering Column and Turn Signal Switch Problems!!
So I have a 96 Camaro and have some problems with the steering column and Turn Signal/Cruise/Wiper switch. First off my switch might be ok, but it is hard to turn on the signal's and it wont turn the bright's on. I also have another problem, you can take the steering wheel and pull it down and to the lower left. Which makes me think it has a pin problem in the column. I have searched for write up's on checking/repairing/troubleshooting this problem but have had no luck. Anyone know of a good write up or could lend some detail before I tear into this? Thanks...
Old Sep 5, 2013 | 06:57 AM
wssix99's Avatar
Save the manuals!
See post #7 - https://ls1tech.com/forums/general-m...d-blinker.html
Do you hear a click? It could be a bad high beam switch or a problem with the linkage. (A linkage runs down the column and engages the switch at the base.)
yep
https://ls1tech.com/forums/general-m...oval-pics.html
https://ls1tech.com/forums/general-m...mn-repair.html
http://www.google.com/url?sa=t&rct=j...,d.eWU&cad=rja
Old Sep 5, 2013 | 08:21 AM
96ss1664's Avatar
I have a lot of reading to do, I'm sure I will have more questions! Thank You!!
No, it seems to try and click but don't. I can push the switch forward and they will come on momentary.
Old Sep 5, 2013 | 09:30 PM
wssix99's Avatar
Save the manuals!
Probably the switch, then. If you take off the lower IP cover, you should be able to observe the linkage/switch and test it.
