Sponsored by: CARiD
ls1 rough idle and hesitation, running rich
Old Sep 18, 2013 | 06:21 PM
bluegoose177's Avatar
Default ls1 rough idle and hesitation, running rich
My '99 ls1 m6 has had a rough idle, hesitation, been back firing and running really rich for the past few weeks since I installed an slp catback. I've changed plugs and wires, O2, tps, and maf sensors. Had it scanned today and the scanner read the maf was faulty, but that's all it showed and it was a cheap scanner. Gonna get another new maf and see if that cures it. Any other ideas of what it could be?
Mods : Lid, pacesetter lt's, 3" ory, slp loudmouth 2
Old Sep 19, 2013 | 12:07 AM
Fry_'s Avatar
I'd try cleaning and re-installing you original maf. Just use isopropyl alcohol and some q-tips.
Old Sep 19, 2013 | 02:03 PM
1_MEANZ28's Avatar
It looks like it should be the maf..since you alreadlt replaced all other possible causes
Old Sep 19, 2013 | 04:12 PM
blade2222's Avatar
Use maf sensor cleaner not q tips.
Old Sep 21, 2013 | 11:46 AM
No luck with a new maf sensor, although it did stop most of the hesitation. Could it be the IAC or a vacuum leak?
Old Sep 21, 2013 | 01:00 PM
dreww's Avatar
Iac should trigger CEL. Yes, vaccuum leak is likely.
Old Sep 23, 2013 | 07:13 PM
Cleaned the iac and throttle body yesterday, still no luck. All vacuum lines look good from what I can see though. Anyone know where I can get a vacuum line kit, or some sizes at least? SES is on, but the MAF was the only thing the scanner showed, and it was replaced.
Old Sep 23, 2013 | 10:30 PM
lt1pwr1's Avatar
You weren't having any issues before the exhaust mods? I would check for burned o2 harness. Can you scan and see if the fronts are switching properly?
Also, double check you have all plug wires snapped down on the plugs and coils.
Old Sep 23, 2013 | 11:38 PM
LS6427's Avatar
You could try a new coolant temp sensor.......
They cause all your issues when they are failing.
Old Sep 24, 2013 | 10:27 AM
Everything looks good on the scanner though, exhaust back pressure shouldn't have anything to do with it, should it? Or could it just need tuned?
Old Sep 25, 2013 | 08:25 AM
Uneverknow's Avatar
I can't see why in the world it would be your exhaust back pressure! I'd keep looking for a different solution. Spray a can of carb cleaner over all vacuum lines and there connections to check for a leak, you'll hear the car will want to choke out.
Old Sep 25, 2013 | 08:57 AM
RockinWs6's Avatar
Did you check the intake bolts? Did you test for vacuum leaks around the intake seals?
Old Sep 25, 2013 | 09:49 AM
cujo18's Avatar
Check the fuse for the MAF.
Old Sep 27, 2013 | 10:48 AM
Sprayed carb cleaner around vacuum lines, injectors, and intake, didn't do anything. Which fuse is for the maf sensor? And is there only one coolant temp sensor or two?
Old Sep 27, 2013 | 11:02 AM
RockinWs6's Avatar
lol you can't tell anything doing that.......check the intake bolts.
Old Sep 27, 2013 | 11:04 AM
poltergeist 02's Avatar
This may be a stupid question, but did you put the maf on in the right direction? There is an arrow on the case that shows the direction of air flow.
Old Sep 27, 2013 | 12:06 PM
Yep, the maf is on the right way lol
Old Oct 1, 2013 | 07:42 PM
Finally found the issue, scanned it again. It said it was the maf, wiring was bad going to it. Thanks for the input though guys.
