Clutch fluid change
So my 65k mile 6spd car I don't believe has EVER had the clutch fluid changed/bled/had the cap off. I noticed after taking a 30 mile drive on the highway cruising in 6th gear, the clutch pedal at the end was much stiffer. I didn't think much of it, got home, parked the car, and opened the clutch fluid cap. I was blown away at what I saw. The fluid level was slightly low, but the fluid had the consistency and color/opacity of 5k+ mile used motor oil
So I did the ranger method of changing out the fluid, and have done so another dozen times or so. I have an extra little syringe that my wife needed to give her bunnies medicine which has a tapered end which fits perfect into the opening at the bottom of the fluid reservoir. I drive 10 miles to work, change the fluid, give 30 or so pumps of the clutch pedal, and call it done. I have done this each day for the past 6 or so days, and after a nice 40 mile drive yesterday which included many blasts through 4th gear, did another fluid change out. Each time I change it, it is still murky, but it has gotten NOTICEABLY better. Now there it is almost getting to the point where I can see the bottom of the fluid reservoir. The pedal is feeling better, no longer firm after a long highway drive, and still grabs nice in each gear. I know the clutch was changed at some point before I owned it, but NO IDEA what it was replaced with. I digress...
My question is, is this a normal amount of time to change out garbage fluid? Or is something else going on that is constantly destroying my fluid... I put around 20 miles on each fluid change, and each time it's noticeably darker. I have been through just about a small brake fluid bottle. Sorry for writing a damn book.
Cliffs: How long/many changes of clutch fluid does it usually take to clean up a never flushed/bled hydro system?
-J
-J
You might also want to consider going with some different fluid like the Motul or ATE.
I've done all the stuff I stated above and the drill mod, AND I'm pushing ATE. I haven't smashed 3rd or higher on the highway lately, but hopefully all that I've done works beautifully.
My issue has been with the fluid boiling. I think this is what most peoples' issue is.
I've been having clutch slippage and low pedal at the top of 4th but not down in the lower gears. That tells me it is fluid boiling.
The issue was at the top of 3rd, but after the first flush it moved to the top of 4th. Once it get it to the top of 6th I'll be happy jk lol
It is a < 10 minute job, with the car on the ground, ALL BY MYSELF, to flush through a full QUART of Castrol LMA, followed by a fill of Prospeed RS683.
If you want to GUARANTEE that your clutch fluid will not boil (attn; all of you long tube owners out there), go with the Castrol React SRF brake fluid, which has the absolute HIGHEST WET boiling point on the planet (but, you WILL pay MUCHO dinero for this stuff
). The Best V8 Stories One Small Block at Time
).$60 a liter, you ain't kidding.
But yes I would very much like to do the remote bleeder, if I need to pull trans for any reason I am definitely grabbing one of those.
Salad: thanks, looks like all the crap I'm pulling from the reservoir is only the beginning. The reservoir was caked with junk that I cleaned out after first time draining.
-J
