vibration at around 60-70mph
Old 10-23-2018, 03:28 PM
BALLSS's Avatar
OP
did you have lower gears put in when you "did your rear end"?
Old 10-24-2018, 07:52 AM
Save the manuals!
wssix99's Avatar
Originally Posted by 5.7stroker
Bump it.
I'm getting a vibration which seems to only occur at 65-75mph also, then when you increase speed it goes away. Natural resonance of the rear suspension? My pinion angle is at 2 deg, so I'm wondering if that is what is causing it. My 2nd guess would be a wheel imbalance, or bent rim.
Vibrations that come and go at those speeds are generally at the wheel and are a classic indicator of imbalance. I'd start with checking the wheel balance and then work back from there, focusing on unsprung components first.
Old 10-24-2018, 09:28 AM
5.7stroker's Avatar
I'll start by swapping the entire wheel/tire combo with someone's that doesn't vibrate and go from there then.
Quick Reply: vibration at around 60-70mph
