vibration at around 60-70mph
-doesn't matter if the road is straight or has a bend
-doesn't matter if I'm in gear or not
-Doesn't matter if I'm accelerating through the mph range, or decelerating through it (I think. I will double check this tomorrow and update it if it's not true)
-I noticed this problem after replacing the 18inch wheels on it with used 17" wheels and new fuzion tires all around. the tires were mounted and balanced on the new rims at Sears auto. After I discovered the vibration, I took it back and asked for a re-balance. (Idk if they really did re-balance it or not...since it's sears lol, but it's still vibrating.)
-I also highly doubt it has anything to do with the rear end, as it's a swapped diff, and I just had the axle shafts and bearings and seals replaced this past Friday. Also has new brakes in the back. Problem was there before that, and after it.
-OH, a while back, before replacing the differential, I was under the car with my mechanic, and he pointed out that the transmission mount was worn (there was play in it), but he said it wasn't to a point where it HAD to be replaced atm, since he knew I was strapped for cash.
based off of these symptoms, what do you guys think it could be? driveshaft?? u-joints (idk if they are good or not)? transmission mounts? something else? I want to have the wheels rebalanced one last time, and make sure whoever does it does road-force balancing.
however, the problem is still definitely there. it just seems like it starts at 65mph now, and goes to like 80? or the vibration speeds up so much that it becomes less distinguishable. I asked my mechanic about the u-joints, he said they were fine. so idk what else it could be.. engine mounts? again, it doesnt matter if I'm in gear or not.
could it be a bad tire, as in non-circular? I really didnt notice this problem until i had the new rims and tires put on, so i think the next thing I will do is either put the back wheels on the front, and see if the vibration follows, or, just put the 18" wheels back on in the back, to see if the problem goes away.
Did you also change the rims? What kind of tires did you put on? Are they all the same? Are your new balance weights getting clipped to the rim or are they glued on the inside?
I had new rims AND tires put on and thats when i noticed the vibration. They are 17" y2k vette replica 5 spokes. They have no dents or anything. Hold air perfectly. Tires were brand new fuzion's from tirerack. Maybe it's a defective tire? I want to swap the back wheels with the 18's to make sure this isn't something mechanical (I'm now paranoid it might be a bent driveshaft or a driveshaft bearing).
I also want to add that today, I accelerated very slowly and smoothly through that problem area speed range, and the vibrations were less noticable. I have to keep driving it and try every possibly combination to see when exactly it happens. Such a headacheWww
If you still have the older wheels and tires, put them back on and see what the result is.
It is also possible that you do indeed have a non-tire related problem that only presented itself once you changed the wheel/tire combo.
But I think that the key in your OP is that the wheels are used.
Have you rotated the tires, front to back, to see if your perception that it is coming from the rear moves the vibration to the front?
Agree with post above about rotating front to back, but add that you should do one side a at a time to help isolate the specific problem.
My experience has been that vibrations are more often due to a bad tire (belt separation, etc.) than a bent wheel. A bent wheel would likely vibrate all the time, increasing with speed.
I also want to note that the problem is less severe with just me in the car. It only happens around 65 or so mph now. Its non existant at lower speeds, and 99% goes away at higher speeds. When It was really vibrating after the new balancing, was when someone else was also sittng in the car, making me thing that it really is a wheel/tire problem?
Also, what do you mean by saying a key point is the wheels are used? Are you saying they are probably damaged? I was hoping that whoever mounted the rims on the tires would say something? Then again...ot was sears who Initially mountes them lol
Without getting under the car you can also try jackiing both rear tires off the ground and rotating them back and forth, by hand, to see if you can hear or feel slop in the drive line or U-joints.
You have said that the problem existed before and after you changed the rear end out, but I would confirm that you have no slop in the U-joint as the next step in diagnosing your problem.
I see after posting that your mechanic says the u-joints are good, it still wouldn't hurt to check them yourself.
I'm getting a vibration which seems to only occur at 65-75mph also, then when you increase speed it goes away. Natural resonance of the rear suspension? My pinion angle is at 2 deg, so I'm wondering if that is what is causing it. My 2nd guess would be a wheel imbalance, or bent rim. Multiple threads describing vibrations at those speeds:
https://ls1tech.com/forums/suspensio...vibration.html
https://ls1tech.com/forums/general-m...nce-issue.html
https://ls1tech.com/forums/gears-axl...ove-70mph.html
https://ls1tech.com/forums/general-m...ing-70mph.html
https://ls1tech.com/forums/gears-axl...ease-help.html
https://ls1tech.com/forums/suspensio...ion-60mph.html
https://ls1tech.com/forums/automatic...on-70-mph.html
Several things can cause vibration, but I would think that I could feel the vibration past 75mph if it was one of these issues:
Bent axle shafts
bent/cracked flexplate (replaced)
worn poly engine mounts (replaced)
worn poly trans mount (replaced)
pulley
driveshaft balance/driveshaft incorrect length
tires
worn u-joints
worn wheel bearing
worn trans rear shaft bushing
bad torque converter
exhaust
