Sponsored by: CARiD
Replacement radiator
Old May 9, 2014 | 04:28 PM
Swoop Dogg's Avatar
Default Replacement radiator
Got home today to see my radiator leaking, all hoses looked good so I pulled the radiator. Replacements available are spectra (autozone) Murray (oreilly) or napa (napa brand). I'll most likely get a 97 lt1 radiator as several members recommend it over the ls1 radiator. Napa one is $60 more than the autozone or oreilly one... Can anyone chime in on what I should get, I can't tell off napa but Murray and spectra are both plastic/aluminum. Can't justify the cash or downtime waiting for all aluminum so that's out... Thanks.
Old May 9, 2014 | 04:30 PM
senicalj4579's Avatar
I got mine from advanced auto parts
Old May 9, 2014 | 04:52 PM
Swoop Dogg's Avatar
There is no advance auto parts in my vicinity.
Old May 9, 2014 | 04:53 PM
I would just order it from rockauto.
Old Jun 11, 2014 | 09:30 PM
jaxcam02's Avatar
My radiator just burst tonight. Luckily I have a bike to ride around until I get it replaced but I figured I would see if the OP has replaced theirs of if anyone else has any suggestions on what price I should pay for a replacement and if the Full aluminum radiator would be worth the 300+ bucks or just go cheap for now.
Old Jun 11, 2014 | 10:23 PM
Majestic9C1's Avatar
I work for Advanced Auto... I am gonna go with the LT1 radiator and use a $40 off coupon of $100 or more...
nice savings if you ask me...
also the LS1 radiator is more expensive for a thinner core.. go figure
Old Jun 11, 2014 | 10:49 PM
jaxcam02's Avatar
^^^ anymore benefits of the LT1 over the LS1. and where can i get that 40 off coupon of 100 or more
Just to check the LT1 radiator is compatible with the manual LS1? just wanna make sure it fits snugly.
Old Jun 12, 2014 | 12:51 AM
Daniel Richards's Avatar
TRT41 but for future just Google "advance Auto Parts Coupon Codes" and check the first couple results and see what the best code you can find to work with what you need to buy.
Old Jun 13, 2014 | 06:57 PM
dailydriver's Avatar
It might actually cool more since it has a slightly thicker core, and/or more rows of tubes inside.
I put one in my LS1 manual car, and it fits perfectly, you just have to cap the extra fittings/nipples on the plastic side tanks which we do not use.
I used large rubber vacuum caps for this, held on with spring, or worm drive hose clamps, but others have come up with better solutions.
Old Jun 13, 2014 | 11:36 PM
knight_rider's Avatar
Had a hairline crack on my stock radiator last year, I replaced mine with an Oreilly one, it was a little over $100. I didn't know about the LT1 radiator or else I probably would've went with that one. This Oreilly one has been going good with no problems tho.
Old Jun 14, 2014 | 02:11 PM
jaxcam02's Avatar
Hey guys, I went with a advanced auto oem replacement. It was on sale @ $104 down from $170 and they had an additional online only coupon of $40 off $100 or more so I paid $70 after taxes. It was frustrating getting the old one out but the new one took 1/2 the time to install and hook up all the hoses. All in all it cost me like $80 bucks w/distilled water and I had the Dex-Cool laying and it took like 7-10 hours of slow steady work and a lot of breaks. All in all it wasn't too bad for the radiator burst when it did. Thanks for the input
