Removed ac from ls1, must I plug up the holes
plug them well if you value the car,
they go to the evaporator which is what made the air cold coming out of the vents when the AC did work,
if you leave it exposed you will ruin that refrigerant plumbing inside the evaporator, and if you ever wanted the AC to work again you will need to put in a new evap. which is expensive and hard to do.
