Dafuq happened in my Engine Bay?
Old 08-02-2014, 12:12 AM
GuardianMagnuSS's Avatar
Default Dafuq happened in my Engine Bay?
Yea what happened here. Drove home from work all highway. Got to 1st set of lights off highway and smoke was coming out of hood pretty good.
Luckily Im a mile from home, made it popped the hood and this. Anyone I wanna say head gasket but Im newb and have never seen this.
Thanks - Mike
Old 08-02-2014, 12:20 AM
WidowMaker_13's Avatar
damn...
Old 08-02-2014, 12:27 AM
Originally Posted by WidowMaker_13
damn...
yup....
Old 08-02-2014, 12:55 AM
SSickLS1SS's Avatar
it seems to be your flux capacitor exploded, did you go past 88mph?
Old 08-02-2014, 01:02 AM
stoning_volcom's Avatar
Seems like that filter exploded, the white looking stuff is oil with moisture
Old 08-02-2014, 06:02 AM
I did hit 90mph and no hyper time! But seriously dafuq?
yea maybe I saw the chocolate milk and started freakin out! But that was just the oil that hit the condenser lines. Oil and coolant looks fine. IDK?
Any other input?
Old 08-02-2014, 06:18 AM
LPE 403's Avatar
Check the oil level....add what's needed (assuming its low), have someone start it while you watch where it's coming from. No way to diagnose a petroleum orgasm like that from just pics....
Old 08-02-2014, 09:12 AM
K will do. I had a breather on the oil cap that I took off yesterday. I think the breather on the passenger valve cover is blocked so pressure built up and it blew.
I'll pull the breather to see if that's the case and hopefully no more sploosh and douche!
Thanks
Old 08-02-2014, 04:28 PM
Breather tube was pinched, crisis averted.
Now to clean up the aftermath. Bwaaant bwaaa!!!
Old 08-03-2014, 01:27 AM
chrysler kid's Avatar
Plug your Pcv back into the intake manifold, I had a similar problem when my Pcv was vented, moisture would clogue the line eventually and the bubble would pop and look like a milk shake under the cap and under the hood
Old 08-03-2014, 09:18 AM
Yea if it happens again I'm gonna run a catch can to the rear.
Hoping this was an isolated incident anyway.
Old 08-05-2014, 10:36 PM
I did hit 90mph and no hyper time! But seriously dafuq? yea maybe I saw the chocolate milk and started freakin out! But that was just the oil that hit the condenser lines. Oil and coolant looks fine. IDK? Any other input?
when this happened did you have the ac on? If so those lines would have moisture on them therefor why the oil turned that cooler it happens.
Old 08-05-2014, 11:53 PM
yea the AC was on but it was late at night and when I got home no light to really investigate.
I saw the milk shake and jumped to conclusions realized the next day was the issue was. Crankcase wasn't vented and found a way out of my breather tube.
Quick Reply: Dafuq happened in my Engine Bay?
