power steering pump pulley remover
this is the one I use/used. picked up a new set at a tool dealer at a swap meet for $40.
http://www.summitracing.com/parts/kdt-2897
If I remember correctly,the pulley is 'plastic' and a 'regular' 3 jaw puller will destroy it.
Yes it will, you need the gm puller. It pulls the little lip at the center of the pulley NOT from the perimeter like you could if the pulley was metal.
Edit: Also, will the puller mentioned in the link above by FirstYrLS1Z from Summit Racing work? If so I live about an hour away from Summit and can pick one up from there...
This puller is very common due to the fact that gm has been using these pulleys for quite some time. Should be readily available locally, and at harbor freight.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
http://www.autozone.com/loan-a-tools...mString=search
