Sponsored by: CARiD
leaking
Old Dec 15, 2015 | 01:25 PM
MIDNITE Z's Avatar
Default leaking
what is it that is leaking? looks like the same color as antifreeze
Old Dec 16, 2015 | 07:24 AM
wssix99's Avatar
Save the manuals!
When the weephole on you water pump weeps, that's where the slow stream of drops end up. It could be a signal that "its time."
Old Dec 16, 2015 | 09:20 AM
Z28 6spd's Avatar
Looks like the A/C compressor is leaking oil and someone had put in the neon colored leak detection dye at some point.
Old Dec 16, 2015 | 02:25 PM
Daniel Richards's Avatar
this right here would be my guess, whats it feel like?
Old Dec 16, 2015 | 02:36 PM
Burken01's Avatar
it's not coolant..
It's a green gel like substance lubricant coming from the AC compressor.. It's just old that's all, it doesn't drip on the ground right? It should be a thick gel
Old Dec 16, 2015 | 04:58 PM
wssix99's Avatar
Save the manuals!
Lot's of other threads about this... It's most likely coolant.
It happened to me. I even use the red stuff and I was perplexed - because something on the components turns it green as it drips down over the compressor. Maybe a chemical engineer can chime in on the organic acid reactions???
A simple mirror under the water pump pulley to inspect the weep hole is a lot easier and cheaper (ie: free) than trying to chase down an A/C leak that is probably not there. (Especially if the A/C works fine!)
Old Dec 16, 2015 | 05:28 PM
celtsean's Avatar
Mine did it. Not the green ,but thick clear yellowish oil. Then later the AC line exploded. And I mean blew upon acceleration from a light,with all kinds of vapors released .Ripped that high pressure line in half.
I replaced it all to keep moisture from getting in there. But dealing with the AC is such a huge pain, I guess I'm giving up AC. At least till I can deal with other more important stuff.
Old Dec 17, 2015 | 09:21 AM
wssix99's Avatar
Save the manuals!
Here's what a typical A/C leak looks like: https://ls1tech.com/forums/general-m...r-leaking.html
There other fluid here my have gathered some green A/C oils around the casing and brought them to the drip party underneath the compressor, but there is a lot of liquid in the original picture that isn't the "green stuff."
Old Dec 18, 2015 | 02:54 PM
dailydriver's Avatar
I already did just that- GLAD to get that weight off of the nose, and the extra belt off of the front pullies.
The ONLY time I miss it is when it is when driving in a rainstorm (no drying defroster setting), and the windows fog up and I cannot open the windows to de-fog.
Old May 31, 2016 | 02:41 PM
MIDNITE Z's Avatar
Originally Posted by Burken01
it's not coolant..
It doesn't drip on the ground
Old May 31, 2016 | 05:41 PM
wssix99's Avatar
Save the manuals!
Did you fix your water pump, yet?
Old May 31, 2016 | 09:36 PM
kingtal0n's Avatar
let us know how it tastes
Just kidding. could be A/C related or coolant, I also see some oil, I think you should pressure wash the engine (gently) clean it up really well, use some paper towels and simple green (and brake cleaner if you know how to use it without melting parts) and once everything is VERY CLEAN you will notice right away where all the leaks are stemming from.
Old Jun 15, 2016 | 02:11 PM
MIDNITE Z's Avatar
No I haven't
Old Jun 15, 2016 | 02:16 PM
wssix99's Avatar
Save the manuals!
No I haven't
Well, that appears to be the source of your leak. In inspection mirror and a look at the weep hole should confirm.
Old Jun 24, 2016 | 06:40 AM
JT2000WS6's Avatar
I agree with the water pump. If the a/c system was leaking that badly there's no way it'd blow cold or even cool.
Old Jun 24, 2016 | 11:24 PM
Burken01's Avatar
that's not true.
It doesn't drip on the ground. It's more of a seepage.. I've seen it on multiple higher mileage fbodys
Old Jun 25, 2016 | 10:42 PM
wssix99's Avatar
Save the manuals!
Well, that's how a "weep" hole (like is on the water pump) would work. It gives a slow warning before bigger problems happen.
I learned this the hard way and let this leak go until I had a very serious water pump failure. New pump = everything is dry as a bone.
Old Jun 25, 2016 | 10:46 PM
2002 SS #476's Avatar
Pag oil from your A/C system. If you open your hood do you see a streak of this on the underside of your hood? This would help to confirm the compressor is leaking.
Old Jul 15, 2016 | 06:35 PM
MIDNITE Z's Avatar
I don't see any streaks on the underside of the hood.
