Sponsored by: CARiD
Driver's seat stuck
Old Feb 23, 2016 | 11:41 AM
30thanniv's Avatar
Default Driver's seat stuck
Driver's seat stuck and doesn't recline. How to fix?
Old Feb 23, 2016 | 11:53 AM
wssix99's Avatar
Save the manuals!
Is it a power seat? If so, does your rear defogger work?
Old Feb 23, 2016 | 01:26 PM
30thanniv's Avatar
The power part works and the rear defrost as well. The lever on the side of the seat to decline is stuck an won't budge.
It seems like a mechanical issue. I don't see an easy way to take apart.
Old Feb 23, 2016 | 02:41 PM
wssix99's Avatar
Save the manuals!
Ah. I recall that I messed with the mechanism once and I had to remove the seat from the car and take off the plastic covers off the side of the seat to get to the workings.
Old Feb 23, 2016 | 06:33 PM
30thanniv's Avatar
Thanks. Fortunately it's at the rake I prefer. Guess it's low priority.
Old Feb 24, 2016 | 06:44 AM
wssix99's Avatar
Save the manuals!
Have you tried pulling up on the seat release to lean it forward to see if that causes the mechanism to start behaving again?
Old Feb 24, 2016 | 04:13 PM
30thanniv's Avatar
Yes I have tried that with no luck. I am afraid to break the handle.
Old Feb 24, 2016 | 05:43 PM
wssix99's Avatar
Save the manuals!
Yea. Best to remove the seat and take a look, then. It sounds like something is just jammed in the mechanism - hopefully an easy fix.
Old Apr 1, 2016 | 07:42 PM
30thanniv's Avatar
Update. Finally got a chance to take a better look. I worked up the nerve and used a small screwdriver under the metal bracket that attaches the recline lever and gently pried up after using some wd-40 on the pin and mechanism. Success!! and no need to take the seat out. Guess previous owner never adjusted it and didn't lubricate mechanism. Now it works like new.
